Jul 1, 2014 8:14 AM UTC
IGES
I saved some parts as "IGES" so that I could modify the assemblies and transform this assamblies to part. But when I try to open again this new "Parts" tells me it is impossible to open them. A problem is occurrying, it has happed a lot of times. I hope I can find a solution, since it was too much work.
Thanks a lot for your time.
Jul 18, 2014 2:40 PM UTC
Hi Garcia,
Can you provide the exact error message given when trying to open the IGES files? It might be in the Message Log.
Jul 18, 2014 3:04 PM UTC
"Koppel_2.igs" kann nicht abgerufen werden
Jul 28, 2014 3:35 PM UTC
I searched this message (also its translation, "can not be retrieved") but its too broad to narrow down a resolution. This is a good candidate for opening a Tech Support case.
