11-Garnet
Imported curves to a single sketch in creo parametric
Is there a quick way to project a bunch of separate (imported) curves to a single sketch without clicking through them all? So i have a bunch of curves or faces that i would like to turn in this case into a cosmetic sketch, but I have had situations where i have wanted to extrude a complex projection too.
So in this case i have a bunch of planar curves (yes they are planar they start out as a projection):
So any quick way to project all of them into a sketch? A script perhaps?
Running creo parametric  9 though i can update to 11 if necessary.
joojaaAnswer
11-Garnet
Oh ok nevermind it has been apparently added to the software in 9.0.2, my backup machine is running a bit stale should probably update to newest.
When in the sketcher choose project, and then in the selection window click review and edit chain. Then choose all curves in feature.
I though i had used this feature. And i did. Alright need to use remote machines until monday.
joojaa11-GarnetAuthorAnswer
11-Garnet
