Imported Family Table data
I have many family tables of hardware items designed in a system that is standalone and had to go through hoops to get the spreadsheet exported from excel moved to this system. I then have to rebuild my master CAD model of the parts and put the columns needed into a blank family table.
In Creo 4, I was able to cut and past the data from the exported .csv file into the family table, save it and then verify the instances with no issues.
Now on Creo 7, I do the import and the spreadsheet turns yellow background and when saved the family table is empty. Open the Excel editor and all of the data is there. It just won't update the Creo file data.
Any suggestions before I open a helpdesk call?
BenLoosliAnswer
Update
CS article written: Article - CS364445 - Unable to add the Family Table instances using Edit with Excel in a specific part in Creo Parametric (ptc.com)
Bottom line is: No Plans to Fix in any release (10, 9, 8 or 7)
Problem is part specific.
no problem on my PC ... Creo 7.0.5.0, Excel 2016
Test no.1
Columns in csv file separated by TAB character.
  • open family table part in Creo
  • open Family table dialog box and then Excel using button in Family table dialog box
  • open csv file in Notepad++ > select all rows > CTRL+C
  • in Excel > CTRL+V
  • close Excel
  • new instances are available in Family table dialog box
Test no.2
Columns in csv file separated by semicolon character.
  • open csv file in second instance of Excel > select all rows > CTRL+C
  • in Excel > CTRL+V
  • close Excel
BenLoosli23-Emerald IIIAuthor
I used your test 2 option with Creo 7.0.7.0 and Excel 365 and also Creo 7.0.5.0.
Neither would import the table data into Creo. They all turn the cell background yellow.
I have edited existing family tables in 7.0.7.0 with Excel 365, so I know the combination should work.
I have tried importing only a few rows and all 526 rows.
I just created 2 rows manually and those rows were verified into the table, including the columns that are driven by relations in the part file. Added the rest of the rows with cut and paste and when I closed the spreadsheet, it wiped out the 2 added rows.
I suggest you to test my option 1. I think you can import your csv file and re-save it as TAB delimited csv file. Also I think you can use Notepad instead Notepad++
