8-Gravel
Jun 15, 2022 12:11 PM UTC
Imported files in Creo came as Solid but for NX some components came as Surface
I am using Creo Parametric Release 4.0 and DatecodeM100
We exported our projects under Parasolid format (.x_t) and several times customer complain the imported files in NX several time some components are imported as surface and not as solid in Unigraphics and they spent time to solve this issue.
In Creo Parametric the files imported came as solid.
I don't have the Unigraphics Application and also I don't have experience with this application , but can you give us an explanation why do you think when NX when import files came with some components as surface.
Thx,
CC
remyAnswer
Jun 15, 2022 1:49 PM UTC
During all my years of CAD data translation software development, this has been the main takeaway: resolving importing issue is pragmatic.
It's another way of saying it but basically, the situation is trying to reconcile two different parties that pull their interest in opposite directions and there is no one size fits all solution and rather find the proper process for your relationship.
Now practically speaking there's a lot that happens during your process that is invisible to the user.
First Creo export to NX then NC imports that file.
The fact that Creo can import as solid its own xmt export is good news but does not bring much to your client.
Siemens or your client can blame our export in the end this will not resolve.
Also the way Creo imports may also rely on a template that does all the job of sewing surface. there can be many reasons for the failure.
Another option, if you don't mind is sending the Creo files to the customer and leave it to NX to import the Creo files.
Most of the times STEP is format of choice though.
And finally if your customer is eager, he can rely on third party CAD healing software.
tbraxton
Jun 15, 2022 1:14 PM UTC
It is pure speculation without some data sets for testing.
It could be related to the accuracy settings in your Creo environment. For the models with an issue are they using relative or absolute accuracy in Creo 4? If you are not using absolute accuracy in Creo you could try changing to absolute accuracy.
Do you have any geometry checks in your Creo models? If so that can also be a cause for translation errors.
Have you tested solid STEP format, Does it have the same issues?
8-Gravel
Jun 15, 2022 1:24 PM UTC
we are using in Creo Absolute Accuracy and open in Creo there is no issue.
In NX, not sure what accuracy the customer used it's used to open the file some of the components came as Surface.
Customer complain the issue is from Creo, but from my point I believe is related to the import accuracy from NX.
I don't have the NX application to test and I was thinking if there is somebody that had this issue and to deal with this issues without spending time in NX to solidify the models with issue.
Thx,
CC
8-Gravel
Jun 15, 2022 1:38 PM UTC
Usually this customer want to have only Parasolid format.
Also it’s difficult because we cannot bother them for more investigations and tests.
Somehow we need to do some investigation on our side and be sure the customer when open the files to have them solid,
Or
if I know a clear procedure that can be done on NX in order the models to he solid and Customer satisfied I can tell them.
Thx,
CC
