Importing Solid Edge Files
I see that creo 7 will import native solid edge files - it is in the pull down options list when one goes to open a file.  The problem is that when the import is completed (assembly file opens in creo) I am not seeing any parts in the model tree.
Is there an additional app that I need to install, or is the way the original file is being saved?
can you upload some data for testing purposes ?
Please take a look at this.  Am I missing some supporting files?  Every time I go to import .asm files, there are no parts in the assembly
