In dual dimension drawing, switching between primary[secondary] or secondary[primary] using pro/program & relations in possible?
If Yes , then How?
Currently dual_secondary_units are in mm & primary units are in inch.
For perticular case I want to show the drawing as inch dimesion in [ ] & for other cases I have to show drawing as mm dimesion in square bracket [ ].
Switching the dual dimensioning type is part of the drawing properties and can not be done via relations or pro/program. One way you can acomplish this is having two different dtl files, one with dual_dimensioning primary[secondary] and the other with dual_dimensioning secondary[primary] and then load the correct file for each drawing.
