Jan 18, 2011 10:27 PM UTC
in need of wayback menu maper help
ProGurus;
Anybody know how to invoke the rev 20 command: "Feature" - "Read Only" -
"Clean" in WF4?
Glen R Wisham
MOEC EW Mechanical Engineering
Space and Airborne Systems
Raytheon Company
805.879.3359 (office)
805.879.3017 (fax)
561.3359 (tie line)
6380 Hollister Avenue
Goleta CA 93117-3114 USA
Jan 18, 2011 10:54 PM UTC
To ensure that certain features cannot be modified at a later time,.you can
make them read-only.
The dimensions, attributes, scheme, and so on of read-only features can not be
modified and are not regenerated when the part is regenerated. However, you can
add features to the parts that intersect the read-only features.
When you make a feature read-only, Pro/ENGINEER makes it, and all the features
that came before it in the regeneration list, read-only.
1. Select the feature in the Model Tree or in the graphics window.
2. Click Edit > Read Only. The R-ONLY FEAT menu appears.
3. Click one of the following commands:
* Select—Pick a feature to make it and all previous features read only.
* Feat Num—Enter a feature external identifier to make it and all previous
features read-only.
* All Feat—Make all features read-only.
* Clean—Remove the read-only setting from the features.
1. Click Done/Return.
Jan 19, 2011 12:01 AM UTC
Pro/Gurus
Thank you one and all... the Pro/Cedure was to use the pull down menu
'Edit' select 'Read Only' (at the bottom) and in the resultant gui click
on 'Clean'
Thank you one and all for your prompt replies.
Glen R Wisham
Raytheon Company
805.879.3017 (fax)
561.3359 (tie line)
