2-Explorer
Insert Constraint?
What is the history of the "Insert" constraint for assemblies?
I'm sure there used to be a constraint called "Insert".  I was using another CAD package for a while and when I came back to Pro/E (CREO) "Insert" was gone...
What's the story?
Dale_Rosema
Don't know if it happened at the same time, but here is a discussion where they changed mate & align to coincident.
https://community.ptc.com/t5/Assembly-Design/Cylinder-with-a-hole-two-insert-mates/m-p/57404
StephenW
At some point, a "simplification" of assembly constraints happened and INSERT got consolidated into to the ALIGN constraint.
On a good note, CENTERED was added and if you have ever used it successfully, it is awesome for conical or spherical surfaces.
doneill2-ExplorerAuthor
2-Explorer
Thanks for the reply!  I figured it was something like that.  ALIGN is gone... so you must mean COINCIDENT...
StephenW
HAHA, yes coincident...
