Insert Symbol pulls in old symbol
We have revised some old symbols that used to be Upper/lower case lettering to be all Upper case lettering. The old symbols are relocated to another directory, not under the current pro_symbol_dir defined in config.pro. When we go to select the symbol, the preview window shows it like we expect, all upper case. When it is dropped onto the drawing, it becomes the old Upper/lower case symbol. Using Windchill, no other drawings in the workspace or loaded in memory as the user erases all not displayed between drawings. We are on Creo 4 m080.
What would cause the system to grab a symbol from another directory that is not even a sub-folder of the main directory defined by pro_symbol_dir.
The really confusing part is that sometimes we will get the all uppercase symbol.
kdirth
Are there old versions of the symbol on the drawing, maybe erased/hidden not deleted?
BenLoosli23-Emerald IIIAuthor
I will check with the users and be sure they look for any hidden symbols and delete them.
Ben,
Are the symbols named the same? Did you erase the old symbol from the drawing first?
They are named the same.
Other symbols when selected from the folder ask if we want to update it, not this one.
It is Creo, not everything works the same. LOL
You will have to delete the symbol from the drawing and then re-add the new desired one.
