Installed Creo 2.0 and the model screen is blank
I've just installed Creo 2.0 and it lauches okay, but when I open a model it doesn't show up in the window. The model tree populates, so I know there is somethig open, but I can't see any datum planes or features, etc. Have tried changing the background color, but that won't change either, I just see a white screen where the model should be.
I should add that I'm running a Dell Latitude with Windows 7, have checked the graphics drivers and have the latest version installed, and have had no issues running Creo 1.0
Being that you are refering to datum planes and features, I'm guessing you are possibly posting this thread in the wrong forum. Can you verify what specific product you are asking about?
Same Problem - EliteBook 2540 with windows XP, all updated drivers.
Any Suggestions?
Discussion was moved to the Creo forum board.
Pedro,
add graphics win32_gdi option into your config.pro file (temporarily) and test Creo 2.0 behaviour. If you see your model then graphic driver is not compatible with Creo 2.0. You can play with graphic card settings or you can wait for new version of drivers or you can replace graphic card or whole PC.
Martin Hanak
