Intermittent Relations Failure
WF4, M080
I have a family table driven extrusion part. The length is driven by
this relation:
IF "ABC123" == REL_MODEL_NAME
CUT_LENGTH = CHAMFER_LENGTH
ELSE
CUT_LENGTH = CALCULATED_CUT_LENGTH
ENDIF
"CALCULATED_CUT_LENGTH" is a reference dimension in a sketch that
changes for each instance, although it is not in the table itself.
There are 3 parts in the table, and they are all in a common assembly.
One of the parts, however, regularly will come up the wrong length, and
it's not ABC123. A regeneration of the assembly always fixes it,
however it's disconcerting to see the assembly wrong and frustrating to
explain to my client that they have to regen the assy to fix it.
Any idea what's happening here and how to fix it?
Doug Schaefer
this relation:
ELSE
ENDIF
Doug Schaefer
