6-Contributor
Is it possible to save columns in Varied Parameter table?
  1. Access to Varied Items window either through Flexibility or Inheritance
  2. Click on Set Displayed Colmuns
  3. Varied Dimension Table Column Setup window is open
  4. From the Not Displayed list move  Assoc. Param to the Displayed list
  5. Close Creo and restart, the Assoc. Param column does not exist and needs be added again.
How to save the column configuration?
Community Moderator
Hi @bduvall,
Thank you for your question.
Anurag
