Jul 5, 2017 5:59 AM UTC
Is it possible with Creo to send bus-bar fabrication details to Busbar CNC machines
Wanted to check, if we design Bus Bars in Creo, which is nothing but metallic strips inside Switchgears or Control panels;
These strips are to be manufactured using CNC machines applying bends at adequate distances and piercing holes in to it.
I know NC Sheetmetal could be used for sheetmetal manufacturing, thus wanted to check the compatibility with Busbar CNC manufacturing machines as well.
Or for some workaround to do so!
Shashank
