7-Bedrock
Is there a maximum number of columns in a hole table of datum points?
I on Creo Parametric 8.0.9.0
Is there a maximum amount of columns in a hole table of datum points?
I would like to add over 23 columns to the hole table of datum points.
I added a bunch of parameters to the datum point feature. These parameters should show up in a table on the drawing. A hole table of datum points is used. And an export of this hole table is needed as input for another application.
While doing this, only 23 parameters, including the standard the standard 'Feature Name', 'X', 'Y', 'Z'  can be included. When adding more parameters, to show up as column, Creo crashes. A fatal error is encountered.
So I was wondering if there is a max to the number of parameters to be added?
Thanks for any reply,
Johnny G
please ask this question to PTC Support.
7-Bedrock
I will certainly do as advised.
Johnny
7-Bedrock
