Is there a way to change a parameter when a certain simplified rep is active?
I have a model that changes based upon a yes/no parameter.  I would like to change this yes/no value when I change to a certain simprep in a drawing.  Is there a relation function I could use to check which simplified rep is active?  maybe some other way of handling this?
Alternatively, is there a way to set a parameter for only a single view/sheet in a drawing?
TomU
Simplified reps will let you suppress and resume things, but to have parameters or dimensions change in different views you will have to use family tables and create separate instances.
