Is there a way to use "%userprofile%" in ENV=PTC_WF_ROOT
I am using Creo Parametric 7.0 7.0.3.0
Is it possible to have the environmental variables for the Windchill cache to be written to set to the users documents using %userprofile%?
For example:
ENV=PTC_WF_ROOT="%userprofile%"\creo7\cache
ENV=PTC_WLD_ROOT="%userprofile%"\creo7\cache_wld
ENV=CREO_AGENT_HOME="%userprofile%"\creo7\agent
Would like it to be based on the user without having to explicitly enter the user name in the psf file. It would be setup in an install package that would be made available to our user community.
    TomU
    TomUAnswer
    Seems like it should work.  I do something similar from a startup script with the cache location, but it should work the same way in the PSF file.
    set PTC_WF_ROOT=C:\ptc\%USERNAME%\WC12_CP4_WGM
    TomU
    TomU23-Emerald IVAnswer
    KrisFloy1-VisitorAuthor
    Excellent!  Thanks for the help.  It works perfectly.
