3-Newcomer
ISOLATE DRAWING LAYERS
I created two layers using the sketch name as a search rule. They are *ORI* & *EC* two layers respectively.
The model tree has the ORI_SKETCH Feature and the drawing has an Original Design view using the isolate 00001_FOR_PTC_CASE_ORI  layer setting.
When the ORI_SKETCH feature name is changed to EC_SKETCH and the 00001_FOR_PTC_CASE_ORI & 00001_FOR_PTC_CASE_EC layers are updated
Finally the "Design Changes" view and the "Original Design" view are not updated.
I have to reset the layer isolate before it updates.
Emeritus
Hi @LH_9352060
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
