Isometric View with Perspective in Drawing
Hi, is it possible to get an isometric, shaded view with perspective added in a drawing? I can't seem to figure it out if it it's possible.
Hi
I think if you can make an isometric view in part or asm mode, you can create a new view in "orient" tab of view manager.
I should begin in part or asm mode an create that isometric view by turning the part or asm so you see it in isometric view.
Hope this helps you out.
Season's greetings
Chris
LeeCasey1-VisitorAuthor
I can confirm this does not work. The perspective is not added to the drawing view.
Anyone else with any suggestions?
Hi again
In part (or asm) in vieuw manager you have to save the created isometric view and give it a name. The same way as you create a flat view of a sheet metal.
Once saved it becomes availeble in your drawing view by changing the view in the view properties to your created isometric view.
If you can creat it in part or asm mode it can be made availeble in your drawing view.
Hope this helps
Regards
Chris
