Issue with Cabling function wanting to merge two separate locations
- 0 replies
- 698 views
- Translate All
I am trying to route a cable harness and it uses several of the same connector that are located next to each other. I keep running into the issue of Creo wanting to merge my location points of the two connectors that are placed next to each other. I designated them as two separate connectors with their own entry ports. Does anyone know what went wrong? How can I fix this so it allows for a separate wire to each connector and keep the network continuous?
I am running Creo version 7. Thanks.
