Issues Inserting and/or Modifying a Feature
  • October 20, 2016
  • 8 replies
  • 3447 views
Hey Everybody,
I have a model with about 100 features.  I have not changed the model in several weeks.  I just tried to modify a feature and the model freezes up...Pro|E not responding.
So I "backed up" the model tree feature-by feature to try to figure out where the regeneration is hanging up.  I found a ROUND that is the issue.  But when I try to delete the round, the model hangs up.  If I try to suppress the round, the model hangs up.  If I try to modify the model accuracy, the model hangs up.
So how do I get rid of this feature?  How do I free up this model from the shackles of NOT RESPONDING?????
I am still using Wildfire 5.0.
TIA,
Neal Rosenblum
Geometrix Engineering, Inc.
www.geometrixeng.com
954-649-9399
Did u try to edit the round feature ?
If you can able to do that , delete all the sets inside that round feature and select any one of the edge in the
3D model to exit the round feature. Once completed the round feature can be deleted.
Dear Rabraham,
I cannot even redefine the feature.  As soon as right click on the part and select REDEFINE, the part hangs up again.
Hi, I would start by suppressing all the features after the round.
You can also take a look at the reference viewer to see the parents of the round has something happened prior to the round that need to be adjusted to fix it. The reference viewer will tell you what they are.
Do you know if the round is actually doing what it is supposed to do? If you can get into it then see if you can redefine or remove any missing refs or failures in the sets.
Hope this helps
Dear Roy,
I am able to move the insertion location up to the BAD FEATURE.  But I cannot insert before it.  I even looked at the parents and just tried to delete them.  Still hangs up.
After nearly 20 years using Pro|E, I have never seen anything like this.
--Neal
Can you suppress all the features then try accuracy change before resuming all?
