Jump to WF5 from WF3
Greetings
Survey says........
Would you jump to WF5 from WF3?
When will PTC end support for WF3?
Our current OS is WinXP
I have not failed. I've just found 10,000 ways that won't work.
Thomas A. Edison
Bill Smith
Design Engineer
Parker Hannifin Corporation
Electronic Controls Division
PH. 574 2544247
www.parker.com
"PLEASE NOTE: The preceding information may be confidential or
privileged. It only should be used or disseminated for the purpose
of conducting business with Parker. If you are not an intended
recipient, please notify the sender by replying to this message and
then delete the information from your system. Thank you for your
cooperation."
Survey says........
Thomas A. Edison
Bill Smith
Design Engineer
PH. 574 2544247
www.parker.com
cooperation."
