KISSsoft and Creo
I am currently working on creating an interface between Creo 9 and KISSsoft. I am following the manual provided by KISSsoft (2023) to complete the necessary steps, but I am encountering difficulties. Additionally, the information available online is quite limited, which makes troubleshooting challenging. (I have tried all three variants from the manual)
Issue: When I click "Create New Gear" in Creo 9, an error message pops up. The message refers to Applisoft, which I´m have also contacted.
However, when I check the specified folder, there is no such file present.
If I create a file with the suggested name and then click "Create New Gear," nothing happens — not even an error message anymore. So what is wrong?
Also this text is in the Creo console: (Nothing there is linking to the Folder above)
Or is there a specific procedure I should follow to make this work (e.g., opening certain files first, executing specific steps, calculate a gear first, etc.)?
Thank you all!
Steve
Edit: If somebody has the same stupid and very rare problem: You must open KISSsoft as administrator, calculate your gear export it (3D). Open Creo and click Create New Gear. Thats all (that i needed to solve my problem and it worked for me) yay!
Or has somebody experience with it?
StephenW
In general, when having issues with 3rd party add-ons, you will get a lot more appropriate help from the 3 rd party tech support or you can try their community if they have one. There may not be many active users in the creo community of the specific add-on you are attempting to us, so their will likely not be much help here.
Steve123456712-AmethystAuthorAnswer
Dale_Rosema
Thanks for sharing your findings!
