Language change back to English
Hi:
I installed Creo Elements/Pro School Edition in my computer, but comes with chiness language. Is any one can help me to switch to English?
Regards
Limei
Hi Limei...
You've posted your quesiton as a blog post. It might be better answered as a new thread on the Creo message board. The link to that board is here:
http://communities.ptc.com/community/creo/modeling
In regards to your question, the easiest thing to do is probably to completely uninstall Creo Elements Pro from your Windows Control Panel. Re-install the application with English selected as the language. In a pinch, you may be able to go to the installation directory where Creo Elements Pro was installed. Inside the "bin" subdirectory you'll see a file called ptcsetup.bat. Double clicking this file will re-run the PTC Setup Utility. Language support is at the bottom of this screen. You may be able to swap back to English by re-running this utility but I'd try the uninstall first.
Good luck!
-Brian
Limei,
to switch Creo Elements/Pro in English, add ENV=PRO_LANG=english into psf file located in ProE\bin directory. Standard name is proe1.psf.
proe1.psf example
// PTC - PSF file: proe
PRODUCT=Pro/ENGINEER
DESC=CreoPro5_M110
ENV=INTRALINK_DIR=__INTRALINK_DIR__
ENV=ILINK_CMD_NAME=__ILINK_CMD_NAME__
ENV=INTRALINK_CMD=%INTRALINK_DIR%\bin\%ILINK_CMD_NAME%
ENV=MECH_LP=__MECH_LP__
ENV=MECH_HOME=%MECH_LP%\%PRO_MACHINE_TYPE%
PSF=%MECH_LP%\install\nt\mech.psf
ENV=PRO_MECH_COMMAND="%PRO_DIRECTORY%\bin\proe.exe" "%PRO_DIRECTORY%\bin\CreoPro5_M110.psf"
ENV=PATH+=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\deflib
ENV=PATH-=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\lib
ENV=PATH-=%INTRALINK_DIR%\%PRO_MACHINE_TYPE%\illib
ENV=PATH+=__DFOR_PATH__
ENV=NMSD_TIMEOUT=300
ENV=PRO_COMM_MSG_EXE=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\pro_comm_msg.exe
ENV=PROE_START=%PRO_DIRECTORY%\bin\proe.exe
ENV=CDRS_DATA=%PRO_DIRECTORY%
ENV=PRO_IMAGE_CONVERTER=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\convert_image.exe
ENV=PROGUIDE_DIRECTORY=%PRO_DIRECTORY%\uifdoc
ENV=SPG_DIRECTORY=%PRO_DIRECTORY%
ENV=PRO_USRMAIN=%PRO_DIRECTORY%\usrprog\umain\usrmain.c
ENV=PROTABLE_DIRECTORY=%PRO_DIRECTORY%\protable
ENV=MOZILLA_FIVE_HOME=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\MOZILLA
ENV=PROTAB=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\protab.exe
ENV=ZIP_EXEC=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\zip.exe
ENV=CLHOME=%PRO_DIRECTORY%\text\pcldata
ENV=PVIEW_PROEPVIEW_HOME=%PRO_DIRECTORY%\apps\prodview
ENV=CV_ENV_HOME=__CV_ENV_HOME__
ENV=VC_VCONF_START=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\ptcvconf.exe
ENV=DEBUG_HLP_DLL_PATH=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\lib\dbghelp.dll
ENV=PTC_D_LICENSE_FILE-=7788@license_server_name
ENV=PROE_FEATURE_NAME=PROE_package_name ()
RUN="%MECH_LP%\install\nt\pro_mech_env.bat"
RUN="%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\nms\nmsd.exe" -noservice -timeout %NMSD_TIMEOUT% &
RUN="%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\xtop.exe"
// USER - PSF
// Add User specific environment or run applications below here
Martin Hanak
Hi Brian:
Thank you for quick responce. it help me. I re-installed Creo and application back to English.
Limei
HI Martin:
Thank you very much to show me another way to solve the problem. It is clear and easy.
Limei
Your solution worked perfectly for me! Way faster than reinstalling all, thanks a lot!!
with creo 2 this is slightly different
to switch Creo Parametric in English, add ENV=PRO_LANG=english into .psf file located in Parametric\bin directory. Standard name is parametric.psf.
Default directory: C:\Program Files\PTC\Creo 2.0\Parametric\bin
Do the same as with the elements instructions above.
Thanks for specificity. This solution works perfectly on Creo 6.0 . Thanks.
3 Years later this fix still works, nice work.
Perfect! Thank you very much.
It works on Creo 3.0 and if you leave the original file and the new edited file, you can choose which language use at the starter of program
Hllo Mario,
Please could you tell me how you did that? I cant locate the directory. Thanks in advance.
C:\Program Files\PTC\Creo 3.0\M090\Parametric\bin
Open the file whit notebloc, add the instruction ENV=PRO_LANG=english at the final of the text and save the file, is all
