Large Assembly Design-post your computer specs
We are looking at new hardware as we are on the low end of the spectrum, and have assemblies up to 10,000 parts in size.
If you run into challenges of assemblies over 5,000 parts-could you post your computer specs and maybe provide insight in how to invest money into a machine for it(GPU best $ for $/CPU Best to invest more in/ETC)
StephenW
StephenWAnswer
This is what we've been buying the last 2 years or so
HP Z420 CONVERTIBLE MINI-TOWER WORKSTATION
-E5 1620 3.6G (better is available now)
-16GB RAM (we've gone to 32gb now)
-256GB SSD
-500GB SATA 7200rpm HDD
-DVD-RW
-QUADRO 4000 GRAPHICS
StephenW
StephenW23-Emerald IIIAnswer
-256GB SSD
-DVD-RW
kdavidson1-VisitorAuthor
what size assemblies are you using?  Is it working well?
StephenW
We are in that 5000 component range, with pdmlink. We don't have particularly good modeling practices so that's a lot of our problem. usually our biggest problems are with drawings.
StephenW
We choose the faster processor available, multiple cores don't help Creo unless you are doing mechanica.
You can look at task manager on your current large assembly and see if you are running out of RAM, if so, add more RAM, fastest ram available)
I don't think anything helps with creo drawings, just my opinion, pro/e drawing mode has sucked for years and I'm assuming they will never do anything to fix it.
Chris3
