Patriot_1776
Layer "rules" issues
  • November 3, 2011
  • 1482 views
I'm on WF4, M190, and I;ve had problems where sometimes the layer rules work, sometimes not. For instance, I've set up a rule in my datum planes layer to put all datum planes there, unless they are the 3 default or GD&T datums (filtered out by name, i.e.: SIDE_X, N_(name), A, etc.). For the planes and other things, it works fine. For surfaces, and datum curves, it doesn't. Has anyone else seen this?
Patriot_1776
Still seeing some odd behavoir. In playing with it more, SOME of the rules don't like the line: "Name != N_*". So, I tried: "Name != *" and it worked......in those case I was having issues anyways, the rest work fine. Weird........
Frank,
upload your data and describe the contents of layers. I can check your layer rules.
Martin Hanak
