Line stock user defined parameters not showing up
I'm trying to setup the piping module for use in our company. In the line stock menu you can set user defined parameters but they don't show up anywhere. I need them to show up in the solid pipe parts.
I have tried with the following test parameters and values
PARAMETER                VALUE
MAKE_FROM               A1612309
TESTMAKE                  BB
TESTPAR                      12
I have tried recreating the pipe after changing the linestock parameters. I have saved the line stock every time.
Is there something I'm doing wrong here?
Catalina
Community Manager
Hi @Matthijs1
Thank you for your question.
Best regards,
Catalina | PTC Community Manager
