bbrejcha
line thickness in Creo
My Dell Precision workstation has a Quadro RTX5000  I spoke to an Industrial designer friend at Dell before purchasing this laptop and he said never skimp on a video card.    384 resolution on a laptop.   So I was thinking and after using it for the past few years of a few enhancements that might be noted for future releases of Creo.   I thought I would bounce this one by the folks on the forum.
So many probably don't know that if you draw a line in sketcher that you can change the linetype *ptc calls incorrectly a font .... or change color.  I want to also change the line thickness and have a few selections or even be able to increment thickness of lines.  Maybe a developer would consider an option to have the line weight pull thru surfaces or solids as if the surface or solid had a slider for opacity.
Once Creo 9.0 question:  What config.pro setting turns off the menu *always on* in creo 9.0
Bart Brejcha
Design-engine.com
