Line thickness problems when saveing to pdf
  • November 20, 2016
  • 4 replies
  • 26560 views
Hello!
After I save a drawing as a pdf file my lines become very thick. Something like this:
Is there a way to fix the lines so that they have a normal thickness?
I'm using creo 2 student edition with windows 10.
Best answer by MartinHanak
export to PDF is driven by following config.pro options
pdf_use_pentable yes
use_8_plotter_pens yes
pen_table_file path_to_file
pen table file - example
pen  1   thickness 0.05 cm;  color 0.0 0.0 0.0;  drawing_color
pen  2   thickness 0.025 cm; color 0.0 0.0 0.0;  letter_color
pen  3   pattern 0.5, 0.2 cm; thickness 0.025 cm; color 0.0 0.0 0.0;  half_tone_color
pen  4   thickness 0.035 cm; color 0.0 0.0 0.0;  edge_highlite_color
pen  7   thickness 0.015 cm; color 0.0 0.0 0.0;  dimmed_color
MH
MH
gtóth1-VisitorAuthor
Thanks, it kinda worked but only with this pen table:
pen 1 thickness .005 in
pen 2 thickness .005 in
pen 3 thickness .005 in
pen 4 thickness .005 in
pen 5 thickness .005 in
pen 6 thickness .005 in
pen 7 thickness .005 in
pen 8 thickness .005 in
And now all my lines are the same thickness. Is there a way to make creo use thicker lines for draving lines and thiner ones for dimension lines?
see default pen mappings in the table. Visible model edges are plotted by pen 1, dimension lines by pen 2.
Pen Number
System Color
Mapping
1
Geometry (white)
Curve (dark blue)
Manufacturing Volume (purple)
Quilt (magenta)
Datum (brown)
Preselection Highlight (cyan)
Preview Geometry (yellow)
Secondary Preview Geometry (pale yellow)
Visible geometry (plot as solid lines, except where noted):
Cross-section cutting plane lines: plot as phantom lines
Cross-section cutting plane arrows and text
Drawing format and boundary
Tag text
Centerline line font with white color
Brown portion of datum planes
2
Letter (yellow)
All items plot as solid lines (except where noted):
Dimension lines
Leaders
Axes and centerlines: plot as centerlines
Geometric tolerance lines
All text (except cross-section text)
Balloon notes
Cross-hatching
Centerline line font with yellow color
3
Hidden Line (gray)
Hidden lines: plot as dashed lines, phantom font
4
Highlight-Primary (dark red)
Selected (red)
Secondary Selected (orange)
All items plot as solid lines:
Spline surface grid (does not plot in drawings)
5
Sheet Metal (dark green)
Sheet metal color entities
6
Sketched Curve (blue)
Sketcher section entities
7
Highlight- Secondary (dark gray)
Toggled sections, grayed dimensions and text, dimmed tangent edges
Dark gray portion of datum planes
8
Highlight-Edge (green)
Spline surface grid
MH
18-Opal
November 22, 2016
As Martin mentioned, it would be beneficial to use a pen table file.
Amit
