Lines too thin on 4K monitor
In Creo View version 5.x the lines on the aforementioned 4K-monitor are extremely thin (I assume the same would be true for Creo). This is especially the case for HLR view. The screen is a 4K monitor measuring 24" and having 196 dpi.
Is there an option in Creo View to increase the line width? If not, I suggest adding this, because the lines on high-resolution devices simply get too thin if kept at one pixel line width.
VeqTor1-VisitorAuthor
Unfortunately there is no answer on this issue, therefore I shall give the topic a friendly *bump*
Anyone...?
Still no line thickness option in Creo View 6.0?
Also, is there a way to increase the line thickness when exporting model views to image files? There is no point in generating a high quality antialiased image file with multi-megapixel resolution when all lines are 1px wide and therefore almost invisible!
*polite bump*
Is there a way, or are there any plans, to adapt/increase the visible line thicknes on high-dpi devices, e.g. on 4K monitors?
Thanks for letting the community know
@VeqTor wrote:
*polite bump*
please contact PTC Support and ask them directly.
Thank you. I did so and hope that they will care.
(the issue is still unresolved on Creo View 6.0)
*bump*
After years still no way to adjust line width in Creo View!
Please FIX!
