6-Contributor
Linking WT Parameters to Drawing
We have the original manufacturer part number as a parameter in the Windchill wt file. I need to get that information into my drawing BOM. How can I go about this? Using Creo 7.
llieAnswer
You can map the Windchill attribute to a Creo Parameter and get it into your models and then from there show the model parameter in your drawing.
Community Moderator
Hi DC_9981462,
Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
llie17-PeridotAnswer
