lock balloon leaders to specific feature id
i have a big assembly with a lot of fasterners. many fasteners are the same. those share 1 bom balloon number.
some fasteners are only used in specific configurations of the model.
in this 1 view i have 1 (nut 1 = N1) lock nut that is always used . and 1 (nut 2 = N2) that is only used in configuration X
when in configuration X i need this view to have the balloon on N2.
the balloon with the same number for N1 is already in a different view
when i have it all set up correctly in configuration X and save it it is fine when i open it
it is when i go to configuration Y that i see that the leader of the ballon from N2 has jumped to N1, the balloon itself is still on its spot so i basicly have a line running tough my view.
when i configure it back to configuration X the leader does not return to N2.
this is very annoying.
i need the balloon AND LEADER to stay with N2, and when N2 is not used i just need it to dissapear. just like the balloons do for normal parts (often only one in the assemlby, so no jumping, just disapearing)
the only workaround that i could think of, and currently using, is to use drawing program and add states with which i hide the balloon when the N2 is not used. this prevents the leader from jumping by removing the whole balloon before it gets a chance to.
this way has become to much work and sensitive to mistakes, as when 1 leader jumps it doent get fixed automaticaly.
does annyone know a way of locking the leader and balloon to a specific feature id?
maybe you can create several repeat region tables in your drawing and use them to display balloons for individual configurations.
hi,
im sure this could work for smaller assemblys, but i think this will stack up fast for larger assemblys
and i imagine it would be more work then what i do now..?
thanks for your suggestion tho
StephenW
If you are using rpt.index and no duplicates, you can not attach a balloon to a specific item.
hi
thats what i have it set to now. how do i need to change it to be able to attach a balloon to a specific item?
StephenW
I don't think there is a solution, at least not an out of the box solution. I assume you are trying to automate drawing create somewhat and I really have no experience in that area.
