Locked Parameter driven by relations
  • November 10, 2016
  • 15 replies
  • 6496 views
Please help
I need to increase the nomenclature length which is driven by this relation (End if statement).  If NB_2=65, The maximum nomenclature_length will be 80.  If NB_2>65. An error occurs. Thanks
/*  RELATION TO CUT NOMENCLATURE INTO 3 PARTS TO FIT IN DRAWING BLOCK
/* NB_1 IS THE NUMBER OF CHARACTERS TO BREAK NOMENCLATURE AT FIRST POINT
/* NB_2 IS THE NUMBER OF CHARACTERS TO BREAK NOMENCLATURE AT SECOND POINT
NB_1=28
NB_2=57
NOMENCLATURE_1=NOMENCLATURE
NOMENCLATURE_2=""
NOMENCLATURE_3=""
NOMENCLATURE_LENGTH=STRING_LENGTH(NOMENCLATURE)
IF NOMENCLATURE_LENGTH > NB_1 & NOMENCLATURE_LENGTH <= NB_2
   NOMENCLATURE_1 = EXTRACT(NOMENCLATURE,1,NB_1)
   NOMENCLATURE_2 = EXTRACT(NOMENCLATURE,NB_1+1,NOMENCLATURE_LENGTH-NB_1)
ENDIF
IF NOMENCLATURE_LENGTH > NB_2
   NOMENCLATURE_2 = EXTRACT(NOMENCLATURE,NB_1+1,NB_2-NB_1)
   NOMENCLATURE_3 = EXTRACT(NOMENCLATURE,NB_2+1,(NOMENCLATURE_LENGTH-NB_2))
ENDIF
2-Explorer
November 11, 2016
What is the maximum NB_2 when the parameter length is 79?
joe_c14-AlexandriteAuthor
If NB_2, the nomenclature_length is still 80.  It doesnt change
2-Explorer
November 11, 2016
I think you asked the wrong question - you want the nomenclature string parameter to have more than 80 characters - As Martin points out, 80 is the maximum number of characters allowed. This answer has nothing to do with the original question concerning the value of NB_2.
For the original question:
Your problem statement:
If NB_2 = 65 then no error for parameter length up to 80
If NB_2 > 65 then some error for parameter length = 80
Test question:
If parameter_length =79 what is the maximum NB_2 for which there is no error?
Try this.
/*NOMENCLATURE="1111111111222222222233333333334444444444" + \
                          "5555555555666666666677777"  /*777778888888888"
NB_1=28
NB_2=65
NOMENCLATURE_2=""
NOMENCLATURE_3=""
NB_1=IF(NB_1>=NOMENCLATURE_LENGTH,0,NB_1)
NB_2=IF(NB_2>=NOMENCLATURE_LENGTH,0,NB_2)
IF NB_1>0 & NB_2==0
ENDIF
IF NB_1>0 & NB_2>0
ENDIF
Hi Andreas
Thanks. Try it but it doesnt seem to change the nomenclature_length. It is set to 80 no matter what i do.. Frustrating indeed
maximum length of string parametr value is 80.
My relations follow...
NB_1=28
NB_2=57
NOMENCLATURE_2=""
NOMENCLATURE_3=""
      NOMENCLATURE_3 = EXTRACT(NOMENCLATURE,NB_2+1,NOMENCLATURE_LENGTH-NB_2)
   ENDIF
ENDIF
MH
Hi Joseph,
I've no problem with the relation you created.
The only limitation is that the NOMENCLATURE lenght can't be more than 80 characters (as said by Martin).
NOMENCLATURE = "12345678911234567892123456789312345678941234567895123456789612345678971234567890"  80 chars
NB_1=35
NB_2=70
What is the error you encountered ?
Pierre
Joseph,
Since we went to Creo 3 we are looking into removing the three parameter lines from our title block all together and use Word Wrap in the cell with only one parameter, TITLE. This way you do not have to worry about the length of each line running out side the box. We have the following in our start parts:
Relation:
TITLE=TITLE1+" "+TITLE2+" "+TITLE3
Parameters:
TITLE1
TITLE2
TITLE3
We have all ready proved it out and currently testing on a test PDM server.
That looks simpler but can you control the number of characters per line.  What does the + sign do again?
