Patriot_1776
Major issue with layers in top-down design using a skeleton.
  • November 9, 2012
  • 0 replies
  • 500 views
I'm using a M080 build of creo, and have run into some major issues in my assembly. I'm using a skeleton to do top-down design, and at the assembly level I CANNOT get the layers in the skeleton to unhide. Even if I unhide the layers in the skeleton, then open the assembly, it still doesn't work. Needless to say this really is causing major problems. The only thing I found that worked, was going into the skeleton and"excluding" the features I wanted to show at the assembly level from that layer (we use "rules-based" layers) and that seemed to work. But that is a total pain. I remember that there was some issues with inheritance model layers not working right in the assembly, but nothing this bad. Of course, that was before creo....
Anyone else seen this?
I think from now on I'm going to do top-down the way I used to, by building my "skeleton" in the assembly itself. That seemed a lot more stable and trouble free.
Be warned....
