Make flexible in Creo
  • March 20, 2017
  • 1949 views
Can you use make flexible command in Creo to make a corrugated tube that has an X, Y, and Z datum points and datum curves. It is modeled using these datum points and curves.
We want to use the make flexible command to bring up the model to make multiple point locations along with four extensions. We are familiar with using the make flexible command for one dimension, but not for multiple dimensions.
Thanks Billy
I'm not sure if this is what you are asking but you can add multiple dimensions to the varied items list by clicking the plus sign at bottom of varied items dialog box.
