making a pipe wrap template for cutting compound miters on tubes
- 11 replies
- 4835 views
- Translate All
I am having trouble creating properly dimensioned drawings of compound miter cuts on HSS square tubes. The annotations are difficult for the shop to interpret. ( see picture attached) So the next best thing is a pipe wrap template that the shop can use to mark the tube for cutting.
I've had some luck:
1. converting to sheet metal and then making a flat pattern drawing and exporting to DXF for laser cutting a marking template and also
2. some luck creating a surface wrap and unfoldng that as well.
Neither one is ideal however, and both were found by accident and not easily repeatable. Furthermore the "convert to sheet metal" method was irreversible so it requires making copies of all the tubes in the model which is a royal pain when there are more than a few parts.
