6-Contributor
Managing assembly reference in part mode
Hello. I am wondering that if it is possible to manage the assembly references in part mode. For example, i would like to open a part in assembly mode, then i will replace the reference for that part in part mode.
tbraxton
tbraxtonAnswer
Yes, this is possible. You need to activate the part in the assembly model. You will then be in part mode while viewing the assembly model with the part in situ. If you have references that are out of the scope of the assembly, you are viewing while you are doing this in then you may not be able to reroute all references. See this link for details on how to do it in Creo.
To Activate a Component (ptc.com)
tbraxton
tbraxton22-Sapphire IIAnswer
