Manufacturing OP model assemblies using MBD, issue with combo state output
Is anyone using MBD for manufacturing OP models? Basically, I have my part (that is being machined) with different Simp Reps to show each OP, I assemble fixture(s) and then start annotating and showing the different OPs within combo states. Everything looks pretty good and then when I try to output to Creo View or 3dPDF (Anark), nothing recognizes my part level Simp Reps so the correct representation never gets shown for my operations.
Again, everything looks great in Creo Parametric so this is very frustrating because I never get a deliverable that is acceptable. At the moment, I think my only work around is to stay in Part mode rather than creating an assembly and bring fixturing in as Copy Geom surface models.
you can the save the model as .PVZ ( CreoView file ext) , there is a setting is creoview recipe file to show simplified reps.
