Mapkey and Copy/Paste
I use CREO 2.
I need to create a drawing mapkey which get the name of a dimension (dxxx)
and copy it in a table cell
(using the parameter &mbr.dxxx in order not to remove the dimension from the view) .
In the mapkey I used the Copy and Paste command but it doesn't work
because the copied value is always the original value (get during the mapkey creation)
Any idea ?
Pier
