Sep 25, 2019 4:49 PM UTC
Mass Parameters
I have created a table which uses a repeat region to display material names and masses of parts in an assembly. So I am able to know that part1 is made out of aluminium and weighs x amount of weight. This is using asm.mbr.part_name and asm.mbr.pro_mp_mass. I am also able to know the total mass of the assembly using just &pro_mp_mass.
I would like to be able to calculate just the total amount of weight for a specific material and store it as a variable. So for example, add all the pro_mp_mass for all components which have a material name which is aluminium, and not take into account for the calculation, the other materials. Is this possible to do? Any help would be much appreciated. I can provide further explanations if required.
Sep 25, 2019 5:52 PM UTC
Thinking outloud………...
Can you sort the BOM table by material type?
Not sure repeat region relations have the ability to add up the weight column numbers.
Sep 25, 2019 5:54 PM UTC
Hi Ben,
I would like to do it automatically if possible, but thanks for your answer
Chris3
Sep 27, 2019 11:37 AM UTC
Does it need to be done on the drawing? You can export the table to a csv and open it in a spreadsheet program and manipulate the data there.
Sep 27, 2019 6:10 AM UTC
did you try filtering repeat region table contents to display aluminium parts, only ?
