Mass Properties Computed VS Assigned
- 18 replies
- 8056 views
- Translate All
I have an assembly that has the weight assigned to some of the library
parts with in it.
If a user forgets to toggle the radio button to "Assigned" it will display
an invalid weight for the assy.
Is there a way when you compute "Mass Properties" to have it to default to
"Assigned" instead of "Computed"
This is an e-mail from General Dynamics Land Systems. It is for the intended recipient only and may contain confidential and privileged information. No one else may read, print, store, copy, forward or act in reliance on it or its attachments. If you are not the intended recipient, please return this message to the sender and delete the message and any attachments from your computer. Your cooperation is appreciated.
parts with in it.
