3-Newcomer
Apr 18, 2013 6:36 PM UTC
Mass Properties of Family Table Instances in Drawing Table
I have a part with a family table with several instances. Is there a way to get the Mass and COG parameters from each instance to show up in a table on the drawing? If so, how would I go about doing this?
Thanks!
Ted Otto
TedOtto3-NewcomerAuthor
3-Newcomer
Apr 18, 2013 9:15 PM UTC
After searching more, I figured it out. If I add a parameter to the family table, and use the parameter found within a Mass Properties Feature, then I can make it show up. I already had the Mass Properties feature in the generic part, but I wasn't able to find the parameters in the part, I had to change to feature, pick the Mass Properties feature and then the parameters I wanted showed up.
Thanks!
Ted
