Master Model
  • October 18, 2011
  • 984 views
Does the top down design technique involving the 'master model merge'
(see https://www.ptc.com/appserver/cs/view/solution.jsp?n=9027)
Design Central
Columbus, Ohio
I'm pretty sure that it is necessary, Doug - at least to create the merge. You could probably work on the resultant parts with a plain-jane Pro/E seat, however...
