Sep 10, 2014 3:18 PM UTC
Material definition and assignment
I'm using aluminum clad sheeting. Working in sheet metal. Creo Parametric Release 2.0
The base metal aluminum alloy is AA 3103 which of course has properties of it's own.....however
One side is Clad with AA 4343, 8-12% of wall thickness
Other side is Clad with AA 7072, 8-12% of wall thickness
How does the community handle this is terms of defining and assigning materals?
Or does this just become a "best guess" aluminum composite?
DHLewisAnswer
Sep 10, 2014 5:43 PM UTC
Bill,
If I understand the situation properly, you might consider defining your combination in an assembly with each material having the correct properties defined for the individual parts.
DHLewis13-AquamarineAnswer
Bill,
