Mechanica Assembly analysis including multiple hydraulic cylinders contacting single member?
Good Day All,
How would one setup an Mechanica assembly analysis where you have 2 cylinders in contactwith one structual member at different approach angles and the structual member deflects (bends) due to the load being applied in such a way that displacement at one cylinder causes the force at the other cylinder to increase while maintaining sytsem force balance?
The piston cavities of the cylinders are connected by hydraulic passages so when you push down on one cylinder rod the other cylinder rod extends. Cylinders do not have the samepistonareas.
Any ideas on how to go about setting this up in mechanica?
I'm not able to use mechanism analysis to do this asmechanism analysis only deals with rigid body members.
This member deflects (bending) under load.
Thanks for any help you can provide,
Don Anderson
