Nov 8, 2013 10:54 AM UTC
Menu "Style" in Creo 2.0
I need to use the command "Stile" or "Style" in Creo 2.0 M080 to create an intersection between two surface, like here:
http://learningexchange.ptc.com/tutorial/737/using-the-style-feature-to-create-a-freeform-surface
Anyway, when i click "Style" does not apper any menu Style... Why?
Thank you.
Nov 8, 2013 1:45 PM UTC
The style feature is part of the ISDX extension, it is not included with the base Creo Parametric package. If you need style, you need to order that extension.
fgosti1-VisitorAuthor
Nov 13, 2013 4:26 PM UTC
Thank you.
Another question: some features that now are in ISDX extension in Creo 2.0 were present in Pro-E Wf 3?
