Sep 27, 2016 2:35 PM UTC
Meterial Density Harness
I have a problem assigning MATERIAL_DENSITY to a Bundle, the program at the parameters window do not allow me to change this option, what do I need to do to resolve this problem in order to calculate the mass of a harness? I already try changing the density of the spool, but it does not work.
Sep 27, 2016 10:56 PM UTC
As far as I know the only way to get define density for the spool elements. The density for a spool is defined differently, it's defined as a mass per unit length as also depends on the cross section area.
