3-Newcomer
Sep 11, 2026 8:22 AM UTC
Midnight Theme icons
Hi everyone,
Reference topic: Midnight Theme not loading from default. | Community
has anybody figured out how to change icons when using Midnight theme? Most of them are OK as they are, but some (such as Edit references) are almost indistinguishable from the background. I found the folder, where the icons are stored (Common Files\text\resource), but unfortunately it seems, that when Creo starts, icons are not loaded from here. I also tried deleting creo_parametric_customization.ui files in CommonFiles/text and in Start folder, but to no success. After trials and discussions with AIs, it seems that the only way is to create small mapkey macros for all such problematic icons and replacing system icons with custom ones where I can use my light variants of the icons. Is there some other way that you know of, how to do it easier?
    Patriot_1776
    Sep 15, 2026 7:49 PM UTC
    I just started using the theme, and yes, I agree, some are a little harder to see, for me the very top row, but overall I like it better
