Mirroring part and copy drawing
I would like to mirror a part and give it a new item number. Let's call the first model "Model A" and the mirrored model "Model B". Is there any way to copy the drawing from Model A to Model B?
Thanks in advance,
Jason
Dale_Rosema
If it is truely a mirrored part, here are a couple of thoughts.
On the drawing state that the Left Hand (or Right) is shown and that the other part number is mirrored. That way if you have changes to make, you do not have to update two sets of drawings.
Or you could use sheet two for the mirror part for views, but refer to sheet one for dimensions.
Dale_Rosema
Or you could follow this discussion about copying parts and drawing:
http://communities.ptc.com/message/188570#188570
jmayer1-VisitorAuthor
I've been following this discussion but I'm not sure it applies. The save as mirrored part option does not give the opportunity to copy the drawing.
In Creo 2.0
Fiile > Save As > Mirror Part
- Dave
Dale_Rosema
Dave,
Does that work for the drawings also or just the model?
Thanks, Dale
Unfortunately only with the model....
Add rename_drawing_with_object to your config.pro file
Then go to file >save as > mirror part
And it should work
