Jun 30, 2014 11:15 AM UTC
Model Manager issue
I have encountered the folowing issue with Model Manager:
A Master Data article has got reserved to my Model Manager user and i cannot unreserve it now, the unreserve button is grayed out. I have unreserved the corresponding 3D model and 2D drawings.
Is there a solution to this problem?
Thank you,
Paul Borlan
lfortnerAnswer
Jul 1, 2014 7:03 AM UTC
How did you reserve the masterdata? Basically there is no MM command to reserve/unreserve masterdata.
Now let have a look at the masterdata parents and let have a look to the "Mastered in Packet" attribute. It holds the Elid or "Element ID" of the packet in which your masterdata has been reserved. Search for this packet using "Element ID" attribute, and if you're allowed, open this packet and [Remove from Packet] your masterdata; it will be not reserved anymore. If you're not allowed, you should ask to the packet owner to do that.
Jul 1, 2014 6:49 AM UTC
Hello Paul,
Do you have check if you have the right ACL to unreserve ?
lfortner14-AlexandriteAnswer
Jul 2, 2014 8:43 AM UTC
First of all I want to thank you for this quick and correct solution.
Secondly, I do not know how i manged to reserve the master data. I think something happened during the creation process and adding the 3D model and 2D drawing to it.
Best regards,
Paul Borlan
