Sep 7, 2022 9:55 PM UTC
model_name + "custom text" in a drawing parameter relation
is there any way to add custom "text" to end of drawing parameter relation below?
we'd like to truncate the "model name last 3 characters" then add text "DOC1"
for our drawing title blocks
DOC_NO=extract(rel_model_name(),1,string_length(rel_model_name())-3)"DOC1"
thanks
Rich
TomU
Sep 7, 2022 10:09 PM UTC
Drawing programs have a greatly reduced subset of valid commands.  You should be able to display this on the drawing by using a single cell repeat region as long as you don't actually need a drawing parameter populated with this value.  What version of Creo Parametric are you running?
TomU
Sep 7, 2022 10:16 PM UTC
Example with Creo Parametric 8.0
Sep 7, 2022 10:10 PM UTC
You had it close.
DOC_NO=extract(rel_model_name(),1,(string_length(rel_model_name())-3))+'DOC1'
Test the extract portion to be sure it gives you what you want.
TomU
Sep 7, 2022 10:18 PM UTC
That will work as long as they want to add the relation to the model, but it won't work in a drawing unless it's added to a repeat region.
joe_morton
Sep 23, 2022 1:27 PM UTC
Do you have 1 drawing per model? You might be able to add the relation in the model itself, then reference that parameter in the drawing. This might be a little more flexible to use than dealing with repeat regions.
